Audio Interfernce Using Sennheiser G3 Audio Kit
Posted by Paul Mcdermott on April 16, 2013 at 4:05 pmHi
I’m a wedding videographer in Ireland and I have used Sennhesier G2 and last year upgraded to the G3 kit.
I always scan for available frequencies in new locations. Sometimes I get bursts of intermitent interference.Here is a link to a very short clip with an example of it.
https://vimeo.com/64158356 password- audioDoes anybody have any idea what it is and how to avoid it.
Thanks in advance
PaulPaul Mcdermott replied 13 years, 4 months ago 4 Members · 9 Replies -
Eric Toline
April 16, 2013 at 7:30 pmYour link is password protected and can’t be opened without it.
Eric
“I push the RECORD button and hope for the best”
John Fishback
April 16, 2013 at 9:36 pmThat might be related to your squelch setting. I don’t have my G3 handy to check, but I believe you can adjust the squelch sensitivity.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Ty Ford
April 17, 2013 at 2:46 amHello Paul and welcome to the Cow Audio Forum.
That sounds like an RF “hit” of some sort. Could be enough smart phones in the area or something else. Have you worked there before? Did you do a scan when you setup?
Getting closer to the transmitter helps, but I had a guy with a smart phone on his belt once and the transmiter a bit farther around his belt. Range went from 50-60 feet before I wired him up to a foot and a half.
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s Blog -
Paul Mcdermott
April 17, 2013 at 10:44 amHi John
My squelch is set to lowShould I change this. If it is set higher does that reduce the range of the signal?
Paul Mcdermott
April 17, 2013 at 10:48 amHi Ty
I always scan the area before I set up the frequencies. Often I get these rf bursts half an hour into the filming, sometimes as really strong bursts and other times weak and then it might go away again.
I keep my phone switched off and try and keep a good ten feet away from people with phones on. -
John Fishback
April 17, 2013 at 2:56 pmYes, it’d probably affect the range as the signal needs to be stronger to punch through the squelch. But, it’d also be harder for the offending signal to punch through. I have no idea how much it’d affect the range. If you can get in that room to test, you can determine if the range is ok and if you still hear the interference.
John
Ty Ford
April 17, 2013 at 3:39 pmI once worked a room in which I was having a monstrously bad time with my wireless. I found a facilities person and asked if they knew if there was anything on. They opened a closet and all the wireless transmitters had been left on. The church in which you shot may have the same thing going on.
Regards,
Ty Ford
Paul Mcdermott
April 17, 2013 at 4:16 pmHi Ty
This has been the case a few times. At the moment in Ireland there is a change in the frequencies. I’m on the new allocation with my new G3 kit, hotels and churches tend to be still on the old frequencies or something totally different as they imported their kit from abroad.
For speeches alot of the time I have to attach my wireless mic to the hotels wireless mic, very messy.
Thanks for your input. I’m going to up my squelch and see how I go.
