Activity Forums Apple Final Cut Pro Legacy Audio Interfaces
  • Audio Interfaces
    Posted by Alexander Gao on November 24, 2007 at 9:09 am
    I posted a while back that I was looking to buy some monitor speakers. I ended up buying the Behringer Truth B2031A monitors. Now I need an interface. I bought the Behringer FCA202 but the stupid thing does not control monitor out levels, only headphone out, leaving me with virtually no control over my output levels. Can anyone recommend a well-built yet small audio interface that satisfies most of the following?
    Connects through FIREWIRE
    L/R BALANCED TRS Output
    Monitor output level control as well as headphone output l.c.
    Uses AC adapter for power, not powered via FW bus
    24bit D/A converters
    Up to at least 96kHz sampling
    $300 or less
    Alexander Gao
    USC School of Cinematic Arts
    John C. Hench D.A.D.A.
    Jerry Hofmann replied 18 years, 9 months ago 2 Members · 5 Replies
  • Jerry Hofmann
    November 24, 2007 at 1:57 pm
    Are you guys really stuck with FW interface?
    How are you monitoring the video now?
    Jerry
  • Alexander Gao
    November 25, 2007 at 1:03 am
    Not stuck. I just would like a firewire interface because it is more robust than having a USB interface. I don’t have an HD video monitor currently, so video out is currently not on the menu. When the time comes, I’ll worry about that.
    UNLESS
    Is there a good box (I’ve seen a few examples from AJA and Blackmagic) that will give me accurate HD out to my 24″ monitor, as well as better audio out than only RCA?
    Alexander Gao
  • Alexander Gao
    November 25, 2007 at 1:07 am
    By the way, when you say “you guys”, you’re referring to me, singular, a college student in a dorm room! So what do ya suggest?
    Alexander Gao
  • Jerry Hofmann
    November 25, 2007 at 8:13 pm
    Depends on the 24″ display model maybe, but Matrox.com has a dandy box for that will do this AND downconvert to SD video as well as SDI outs etc. HD Sdi and analog outs too… For a grand… Keep in mind it’s an output only box, but allows you to lay SD to tape from HD sources.
    AJA and Blackmagic’s boxes are a bit less pricy, but only send the scaled signal to the computer displays they work with. Not the rest of those goodies…
    Jerry
  • Jerry Hofmann
    November 25, 2007 at 8:15 pm
