Activity Forums Apple Final Cut Pro Legacy audio inpoint shortcut?
  • audio inpoint shortcut?
    Posted by Aaron Metchik on June 27, 2008 at 4:28 pm
    If I ripple the video track of a clip so that it’s in-point starts significantly later than the audio does on the timeline, and then I clic on the clip to bring it up in the viewer, when I hit Shift-I, it takes me to the point where the video track becomes visible in the timeline. Is there a different shortcut I can use to take me to the Audio in-point?
    Aaron
    Jericha Senyak replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jericha Senyak
    June 30, 2008 at 8:49 pm
    Any time your playhead is positioned over a clip in the timeline, double-clicking that clip will open it in the Viewer with the playhead in the same position. So if your playhead is positioned at the audio In point in the Timeline, double-clicking the clip will display the audio In point in the Viewer as well. It’s not a shortcut, but it will get you there without scrubbing.
