Activity › Forums › Adobe Premiere Pro › audio in timeline
audio in timeline
Posted by Bwk Idaho on February 21, 2007 at 8:48 pmI am new to Premiere Pro (I have version 7.0) and am having problems with the audio in the timeline. When I import clips into the storyboard the audio works great, but once I move the clip down to the timeline I loose all audio. Do I have to turn the audio track on or something? Any help would be appreciated. Thanks ahead of time.
Blast1 replied 19 years, 7 months ago 4 Members · 8 Replies -
Dan Chapman
February 22, 2007 at 2:40 pmMPG files are not Premiere’s favorite format – they’re generally heavily compressed and not intended for editing.
You may have better results if you convert your clips to AVI’s first. There is an MPEG-aware version of VirtualDub at:
https://fcchandler.home.comcast.net/stable/
There is additional information here: https://en.wikibooks.org/wiki/Movie_Making_Manual/Post-production/Importing_From_a_DVD
Brian De herrera-schnering
February 22, 2007 at 4:12 pmAlso, check your playback settings to see if audio playback is set to internal or external device.
Brian
Dan Chapman
February 22, 2007 at 5:03 pmAh, yes – in re-reading your question, I think ringabinn is on the right track. Your playback settings may be set to output the audio to, for example, your DV/Firewire device. That would make the audio play through your camcorder or DV deck instead of your PC’s speakers.
Bwk Idaho
February 23, 2007 at 2:54 pmThank you for the ideas…but that didn’t work either. When I selected the option to show the wave form for audio down in the timeline it was flatlined…no audio at all. Again, when I play the clips up in the storyboard they work fine, it is only when I move them down to the timeline that I have problems. Thanks again for the time spent in searching for a solution.
Dan Chapman
February 23, 2007 at 3:11 pmIf you drop an AVI or MOV onto your timeline, does the audio show up?
Blast1
February 23, 2007 at 8:12 pmq[BWK Idaho] “These are .mpg files”
What kind of .mpg? Ppro 1 only handles mpeg1 files barely and you need quicktime installed, forget Mpeg2, divx, mpeg4, and mpg files with MP3 audio embedded.
