Activity Forums Adobe Premiere Pro Audio in timeline
  • Audio in timeline
    Posted by Milko Misu on May 2, 2010 at 9:32 am
    Im using Premiere CS4.
    They problem Im having is I want to use 2 different wave sounds at the same time.
    Put when I drag one wave sound from the Project window in automatically turns in Audio 5 even though I didn´t select it to get there. Then when I trying moving it up to AUDIO 1.2.3.4 it refuses.
    And same time if I drag another wave sound it comes up in same audio 5.
    Jeff Pulera replied 16 years, 4 months ago 3 Members · 2 Replies
  • Santanu Bhattacharjee
    May 3, 2010 at 6:28 pm
    You can drag the audio if all the audio layers are in the same format
    – Sampling rate, no of channels, bit depth.
    If you are using PP cs$ I assume you must be also having a audio editor like Adobe Sound booth. You can convert the second wave to the same sampling rate as the first.
    https://www.santanu.biz
  • Jeff Pulera
    May 3, 2010 at 8:39 pm
    The default audio tracks match the project settings, for instance 48k 16-bit stereo. If you drag in a mono audio clip, Premiere creates a new MONO audio track, you can’t put the MONO clip in the existing stereo track.
    Either convert the file to stereo (if that is the case), or you can right-click the left part of audio track and delete unused audio tracks, so when you bring in the new clip it can be Audio 2 instead of 5.
    Jeff Pulera
    Safe Harbor Computers
    https://www.sharbor.com
