Activity › Forums › Apple Final Cut Pro › Audio in FCPx
  • Audio in FCPx
    Posted by Madhuri Karia on January 25, 2012 at 3:40 pm
    I am shooting video on a Canon XF 100 and when I import using Aunsoft video convertor I don’t get both audio channels in FCPx just channel 1 – how can i view and hear both audio channels – I can hear them on the camera play back so I know they are definitely there – can anyone help please (I am not very technical either). I am doing an interview on Friday so need to sort out by then. thanks
    T. Payton replied 14 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • T. Payton
    January 25, 2012 at 6:33 pm
    First check if you might actually have both channels in the inspector. See here:
    T. Payton
    OneCreative, Albuquerque
  • Madhuri Karia
    January 30, 2012 at 1:47 pm
    Yes have already checked the inspector and there is no audio on the footage where I have recorded through channel 2. It is definitely only picking up channel 1
  • T. Payton
    January 30, 2012 at 4:15 pm
    Can you post a very short clip of the original footage before you converted it. When you reply you will see a small floppy disk icon and you can use that to upload a file, and then you will be provided a link.
    I’ll bet we can get it figured out.
    T. Payton
  • T. Payton
    January 30, 2012 at 7:53 pm
    Actually I found some MXF footage. Looks like the audio is captured separately. Interesting. So it is apparently something with the conversion software.
    Sorry I couldn’t help further.
    T. Payton
  • T. Payton
    January 31, 2012 at 4:58 am
    Hold the phone. I found the solution. Its an app called XfcpX that will properly rewrap and combine the files needed. It’s free and you can read about it here:
    https://pika.dk/?p=406
    Make sure you read the instructions, as it requires that you use the Canon XF Utility.
    – T.
    T. Payton
  • Madhuri Karia
    February 13, 2012 at 3:34 pm
    Hello
    Thanks for that. I have tried it and it is coming in ok with the 2 audio channels but in fcpx the video is either out of sync with the audio and keeps stopping and starting or I get an error message saying that my disk is to slow and frames are missing. I am using a brand new mac which is fast enough to cope with this so that shouldn’t happen.
    Any ideas on how to solve that ?
    thanks
  • T. Payton
    February 15, 2012 at 12:40 am
    Wierd. Can you transcode and create optimized media or proxy?
    T. Payton
