Activity Forums Apple Final Cut Pro Legacy Audio in FCP
  • Posted by Randy Johnson on May 27, 2010 at 12:19 am
    I am using FCP 7 and I shoot with AVCHD. After I log and transfer the clips into FCP they all have the “stereo pair” checked. I dont have independant control over the audio with it checked. Is there a way to get the clips to come in without the stereo pair? Also is there a way for FCP to have a mixed mono output?
    thanks
    Randy
    Randy Johnson
    Rando1968@comcast.net
    Randy Johnson replied 16 years, 4 months ago 3 Members · 4 Replies
  • Michael Sacci
    May 27, 2010 at 3:35 am
    Simple click the stereo pair and the link will be broken, then pan both channels to the center and it mixes the mono.
  • Randy Johnson
    May 27, 2010 at 3:48 pm
    o.k. cool thanks. I got this to work on a “per clip” basis. is there a way to make a “global change”? So everytime I bring in a clip it will have the stereo pair unchecked and come out mixed?
    Randy Johnson
  • John Fishback
    May 27, 2010 at 7:51 pm
    I’ve never worked with AVCHD, but with other formats in L&T in the Import Settings tab next to the audio select buttons you’ll see a symbol. Clicking it will designate the transferred audio as stereo or mono.
    A way of dealing with this if you have a lot of clips already in a sequence is to change the audio of the first clip to the way you want it, then copy it (Cmd-C), select all the following clips and Paste Attributes (Opt-V) and in the audio choices check Levels & Pans, click OL and the change will be applied.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Randy Johnson
    May 28, 2010 at 3:28 am
    Nice! thanks John I think that will work. Unfortunatly when I use the log and transfer tool with my raw theres only one audio option basicly audio or not and it says audio will be imported in stereo.
    Randy Johnson
