Activity › Forums › Apple Final Cut Pro Legacy › audio in fcp
audio in fcp
Posted by Ace Cruz on August 26, 2007 at 3:30 amis there a way to boost the sound pass +12 dp on the time line or audio mixer in final cut pro?
I just finished a feature film and the dialogue for some of the actors are very low and I and I want to amplifie the soundl, but it only let’s me go as high as +12 dp . help.Ace Cruz replied 19 years ago 3 Members · 5 Replies -
Tom Wolsky
August 26, 2007 at 3:44 amWhat version of the application are you using?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Ace Cruz
August 26, 2007 at 6:21 ami am using FCP 6.0.1 . I tried doubling the audio track, but it makes just a little difference. Is there any other way to amplfy the sound in final cut or sound track. if so, how?
thanks. -
Tom Wolsky
August 26, 2007 at 7:52 amUse Modify>Audio>Normalization Gain. This will apply a Gain filter and also give you conrol for setting the level for the whole clip.
All the best,
Tom
Michael Gissing
August 27, 2007 at 5:48 amIf you are planning on exporting the audio via OMF, then check if normalising will cause the normalised clip to be exported. This is not what the audio post people want. They want the unprocessed.
A quick and non destructive way to add more gain is to add the compressor limiter plugin and there is more gain there to be added after you have done the basic +12db.
Ace Cruz
August 31, 2007 at 8:40 amthanks for everyone’s help. How do I put it back to it’s orginal state. I have decided to give it to a professional sound person to fix the problem. how do i undo my changes on my audio clip?
thanks
