Activity › Forums › Compression Techniques › Audio in Compressor
  • Audio in Compressor
    Posted by Adam Pardy on August 9, 2010 at 4:00 pm
    Hi all,
    I’m looking to configure compressor and qmaster within our workflow. Having fought with the clustering every step of the way I ahve that configured how I want it. I’m now having an issue with the presets for Compressor our finished fcp projects have 2 pairs of stereo audio one original track and one with just soundtrack for overdubbing in foreign markets. I can’t seem to find an option to get this as an output on compressor, logically pass through would do this but it always gives me stereo output. Any ideas on how I can get compressor to do this?
    Adam Pardy replied 16 years, 1 month ago 2 Members · 2 Replies
  • Mark Spano
    August 9, 2010 at 5:41 pm
    [Adam Pardy] “our finished fcp projects have 2 pairs of stereo audio one original track and one with just soundtrack for overdubbing in foreign markets. I can’t seem to find an option to get this as an output on compressor, logically pass through would do this but it always gives me stereo output”
    It is likely your sequence settings in FCP that is giving you the grief to begin with. Sequence settings need to specify four audio outputs. Then any quicktime you export (using current settings) will keep the four outputs intact as audio tracks. Send that into Compressor and use input-passthrough and it will remain four audio tracks.
  • Adam Pardy
    August 9, 2010 at 5:54 pm
    Yup thats all configured, all projects use a standard project template. I’ve actually had mixed results some of the files have actually turned this into what QT7 thinks is 3.1 and as such effectively removes one of my tracks. I’m running another test now but I don’t think this is the problem. Thanks anyway
