Activity Forums Adobe After Effects Audio in AE 6.5
  • Audio in AE 6.5
    Posted by Changeman on April 26, 2006 at 3:28 am
    Hi I Render my Comp out and the audio don’t work, But If I Render it from File,make movie the sound works can someone please help me ? Thanks
    Changeman replied 20 years, 3 months ago 2 Members · 4 Replies
  • Tim Kurkoski
    April 26, 2006 at 6:20 pm
    Standard previews (pressing the space bar) don’t play the audio. Use RAM preview instead (zero on the keypad), or you can preview the audio only (period on the keypad).
  • Changeman
    April 26, 2006 at 8:44 pm
    Thanks. But you did not get the understanding of my post. When I Render my comp out To make movie, It do not render the sound. If I go to comp,make movie the sound would not be there in my final render. But If I go to file, make movie the sound is there. The only thing that I do differant is the make movie. One from comp, make movie the other is from file, make movie. Is there a setting in my render Que that turn the sound on or off.
  • Tim Kurkoski
    April 28, 2006 at 3:53 pm
    Well, yes, you can turn off audio export from the render queue. And by default, many of the preset render settings options do not have audio enabled. Make sure that you are using a format that supports audio (AVI, QT, etc.). Some of the default presets render an image sequence, which obvious will not have audio.
  • Changeman
    April 29, 2006 at 8:05 pm
    Thanks, I see what you mean. I’m so glad its working.
