Activity Forums Adobe Premiere Pro Audio Importing
  • Audio Importing
    Posted by Richard Hutt on September 16, 2010 at 6:40 pm
    Just upgraded to Premiere CS5. When importing clips, I want to import audio as mono. In the field I record Nat sound on channel 1 – SOTs on channel 2. I need to separate these so when I edit i can leave the Nat Sound off of the timeline. I do the required steps in “Map source audio channels on import” BUT when i load the clip into my Source Monitor to edit, the clip only has 1 channel of audio, and it is a stereo clip. I had no trouble with this in CS4. Is this a known bug and can somebody inform me how to fix it. And i did look at all the forums before i posted….also went through 159 posts on the Adobe site before i came to the Cow.
    Richard
    Todd Kopriva replied 16 years ago 3 Members · 3 Replies
  • Mike Cohen
    September 16, 2010 at 9:33 pm
    Select the clip in the bin, then click Clip>Audio>Breakout to Mono
    then when you drag it to a sequence it takes up two mono tracks instead of one stereo track.
    Other edit systems do this by default – that took some getting used to after learning NLE on Media 100.
    Mike Cohen
  • Richard Hutt
    September 17, 2010 at 12:06 pm
    Thanks Mike I appreciate your help. I read exactly what you just told me to do and that works fine. I was just hoping I could save a step and not have to do that. Do you think this is some kind of bug that the Capture tool has? Should I notify Adobe about it?
  • Todd Kopriva
    September 18, 2010 at 6:21 am
    The answer to that question is almost always ‘yes’.
    You can submit bugs and feature requests here:
    https://www.adobe.com/go/wish
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
