Activity Forums Adobe Premiere Pro Audio Import Error
  • Audio Import Error
    Posted by Mike Wolfe on August 13, 2005 at 5:13 am
    i’m getting an error message whenever i try to import anything. the message is:
    Disk Write Error. Verify drive connections, available disk space and disk access privileges.
    any idea what might be causing this? i just recently purchased a new laptop and installed this, and reinstalled after seeing this message to no avail.
    really frustrated because i have some music videos to edit but i’m unable to import the music files. actually, i can’t import ANY file without seeing this message. help!!
    Mike Wolfe replied 21 years, 1 month ago 2 Members · 2 Replies
  • Scott
    August 13, 2005 at 5:23 am
    Sounds like something with the scratch disk settings. Make sure that your scratch disk is set to the correct drive and not full.
    Scott
  • Mike Wolfe
    August 13, 2005 at 5:50 am
    yes thanks! i figured it out and came back to the board to let everyone know…it was indeed the scratch disk. for one reason or the other it was set to a folder that didn’t exist, despite the reinstall. thanks again for your help.
