Activity › Forums › Apple Final Cut Pro Legacy › Audio Hum-Need Removal Tips
Posted by Cbswanay on May 10, 2007 at 12:33 amI have a line hum in the audio of a recent shoot. I need to remove it. Does anyone have any good tips? I have FCP and STP.
13 replied 19 years, 4 months ago 4 Members · 5 Replies -
13
May 10, 2007 at 6:13 amUse STP, set your noise print and then reduce the hum. I have seen more detail about this in past posts, I am sure a search would bring up plenty of info.
Michael Gissing
May 10, 2007 at 8:28 amLine hum is either 50 or 60 hz depending on country. A notch filter can be used set to the frequency, rather than using STP to noise reduce. YOu can usually get a cleaner removal with good tight notch filtering.
Walter Biscardi
May 10, 2007 at 10:37 am[zrb123] “Use STP, set your noise print and then reduce the hum. I have seen more detail about this in past posts, I am sure a search would bring up plenty of info.”
I’ll second that, we just tried that here the other day and it does work very nicely. Once you launch STP, you can go into the Help menu and search for Noise Print to get detail on how to use it. Better than anything within FCP.
Walter Biscardi, Jr.
HD Editorial & Animation Broadcast TelevisionAll Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Cbswanay
May 10, 2007 at 1:25 pmThanks.
CAn you give a little more step by step. Is this using FCP or STP?
I’ve tried the set noise print and that really didn’t help much at all.
Someone has also suggested using a comb filter, but I can’t find one anywere-FCP, STP or Audition. -
13
May 11, 2007 at 12:44 amThere have been several posts that give detailed instructions on how to do this using sound track pro like I said before, the sound track pro manual also gives instructions.
