Activity › Forums › Panasonic Cameras › Audio Hum HVX200 & LH900
Posted by Jim on September 18, 2006 at 1:55 pmProblem: mechanical noise/hum when XLR audio cables attached to HVX 200 when an AC powered Panasonic LH900 LCD is hooked into component out.
The physical set up:
Battery powered HVX200 with XLR to audio inputJim replied 20 years ago 3 Members · 6 Replies -
Jeremy Garchow
September 18, 2006 at 2:50 pmDid you put a ground lift on the ac for the monitor? You tried two different power supplies for the monitor, you said?
Jim
September 18, 2006 at 3:18 pmJeremy:
Thanks for the quick response re: ground lifter.
Good thought, but didn’t work. The hum is still there.Yes, I did try powering the LH900 with both an NRG and and Aspen power supply.
Also, Just for grins I pluged the camera composite out to the LH900 video in and there was no hum. However, when I touched the XLR connector there was a tiny click and a slight increase in white noise.
So, major spotlight on the component cable system, and still a shielding problem.
Thanks again,
Jeremy Garchow
September 18, 2006 at 3:34 pmWe use a 900 with an HVX but we run exclusively off of battery. We have two trim packs just for the monitor that are on a constant cycle. If we are out far on location with no power we also have some regular anton’s that we can sacrifice if not running a big body camera, if we need more battery we just rent. Sorry to say I have not tried to power the monitor with AC, but if I find something that works, I’ll let you know. The component cable does leave a little to be desired on the HVX.
Jeremy
Gary Adcock
September 18, 2006 at 11:59 pm[Jim Cunningham] “Thanks for the quick response re: ground lifter.
Good thought, but didn’t work. The hum is still there.”Jim
Did you try the choke that came with the HVX200?
panasonic includes a magnetic choke as part of the HVX’s basic package, and it is intended solve this issue when using AC power instead of the batteries.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Jeremy Garchow
September 19, 2006 at 12:48 amI thought the ferrite core was for connecting the firewire cable straight from the cam to a pc?
Jeremy
Jim
September 19, 2006 at 1:56 amI too thought the ferrite core was for connecting the firewire cable from the cam to a pc, but It’s worth a try. I’ll let you know how it works out.
Thanks again for your insights.
