Activity Forums Avid Media Composer Audio hardware input question
  • Audio hardware input question
    Posted by Michaelhelenek on November 18, 2005 at 5:10 pm
    Hello folks,
    I need to do some voice over work for my documentary. I own the mic, equiped with XLR output and the G5 w/ Final Cut Pro and Avid.
    I’m looking for some type of card/box/interface that will get me from XLR audio into my computer. I’m not looking for some huge I/O video device, as I’m only using DV from camera input. I just need XLR to FCP input.
    Do small mixers or boxes exist with Firewire or USB connectivity, or XLR audio to USB/Firewire?
    Any recommendations?
    Thank you.
    Michael Helenek
    Video Editor
    Donosnh replied 20 years, 9 months ago 3 Members · 2 Replies
  • R. Hewitt
    November 18, 2005 at 5:22 pm
    We use a professional USB device called PUC from Yellowtec. It’s not cheap but provides a broadcast grade solution with virtually no latency and provides options for several wiring looms including XLR for analogue and digital sources.
    Info here.
  • Donosnh
    November 22, 2005 at 7:24 pm
    Digidesign MBox 2 is a great choice. It offers 2 audio inputs which can be either XLR or 1/4″ phono. You can connect microphones or instruments. You connect the Mbox with USB to your computer. It also comes with Protools LE software which is a full edit and mix workstation. If you can afford it, later you can add DV Toolkit which features a broadband noise reduction tool which is great for cleaning up location sound and a tool for dialog replacement. You can check out info and compatability on Digidesign’s web site.
