Activity Forums Adobe Premiere Pro Audio handles when editing an audio file in Adobe Audition
  • Audio handles when editing an audio file in Adobe Audition
    Posted by Damian Nossent on April 25, 2018 at 11:18 pm
    Hi all!
    I would like to edit some of my audio in Audition, but when I click on “Edit in Audition”, the clip is replaced with the Audition one and I can’t roll my audio anymore. After some research I found that’s it called “Audio handles”.
    So what I want to do is: edit a clip in Audition, but keep the full audio length.
    I hope someone knows a solution for this.
    Damian
    Damian Nossent replied 8 years ago 3 Members · 3 Replies
  • Jon Doughtie
    April 26, 2018 at 1:23 pm
    Remember, you do not have to enter Audition through Premiere Pro. You can open it independently, open and work on your file, and save it with a new unique file name. Then close Audition, hop back into PPro and import your new unique media. Original remains untouched.
    Some would say that is a rather old-fashioned way to do things. Perhaps it is. It also works.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Paul Neumann
    April 26, 2018 at 1:32 pm
    You can change the length of handles for rendered clips on the Render and Replace dialogue pop up.
  • Damian Nossent
    April 30, 2018 at 5:27 pm
    Just an easy work around. Thank you.
