Activity Forums Apple Final Cut Pro Audio greyed out after cutting with razor blade tool
  • Audio greyed out after cutting with razor blade tool
    Posted by Rob Onekea on August 2, 2021 at 9:10 pm
    I’ve been working on this project for the past week, but today all of a sudden when I cut my video and audio (separate files) the video cuts fine but the audio greys out from that point. I’ve read other threads about possibly soloing the clip or the roles is turned off, and neither of those is the issue. It’s literally driving me crazy at this point.
    I’m going to try and compound clipping them together to see if that works, but I’d still like to know what is causing this glitch in the first place. Possibly a setting was adjusted somehow? Totally clueless.
    Appreciate the help! Thanks.
    Rob Onekea replied 5 years, 1 month ago 1 Member · 1 Reply
  • Rob Onekea
    August 2, 2021 at 11:21 pm
    UPDATE: So never figured it out and deadlines loom, so I simply re-imported the audio and everything was fine. What caused it to tweak on me, still not sure.
