Activity Forums Apple Final Cut Pro Legacy Audio Glitching Problem
  • Audio Glitching Problem
    Posted by Brett Putman on July 31, 2011 at 5:59 am
    I am having a problem with a FCP edit where my audio track is randomly hiccuping or glitching.
    I am editing a music video, so it is kind of crucial that the audio I export is perfect.
    My audio settings are:
    48khz
    16 bit
    Channel Grouped
    I have ran into this problem before, but I dont remember the proper way to go about fixing it.
    Tom Megalis replied 15 years, 1 month ago 3 Members · 3 Replies
  • Brett Putman
    July 31, 2011 at 6:12 am
    Never mind.
    Found a fix.
    Just converted the mp3 that I was using to aiff.
  • Charles Blackwell
    July 31, 2011 at 9:00 pm
    According to Google, you and I are the only people experiencing this problem – and I see you didn’t get an answer here. Please let me know if you find a solution – charles@watermark.ab.ca – and I will do likewise. It’s odd, playing the timeline, the audio is perfect – but as soon as I export (even just to QT) their are little hiccups throughout it.
  • Tom Megalis
    August 16, 2011 at 3:53 pm
    Is the audio you are using an MP3? If so, that’s the problem. Re output the audio track from your Itunes (or whatever) as a WAV or AIFF. Put that in and it should be clean and work great.
    Hope that helps.
    T
