Activity Forums Adobe Premiere Pro Audio glitches when exporting master file
  • Audio glitches when exporting master file
    Posted by Ludmil Kazakov on October 23, 2016 at 10:07 pm
    When exporting the master file with sound there are areas where audio pieces get looped.. when i refer back to the project there is not even an audio file there.. . even when i export just a WAV of the audio the issue is still there.. In an hour and 45 minute feature this happens 4-5 times.. this is unacceptable and very frustrating..
    I am on the original Premiere Pro 2015CC version, little nervous about updating in the middle of the project.. i tried cutting out the looped audio from the wav export and re-exporting in the newest version Premiere and it worked fine..
    Anything I can do to make this go away? clean cache?
    Ludmil Kazakov replied 9 years, 10 months ago 2 Members · 4 Replies
  • Ludmil Kazakov
    October 24, 2016 at 2:29 pm
    my idea is to have it done right first time and not to have to export it twice, once for sound once for picture.. at this stage its not a master but needs to be watched by producers without glitches in the audio.. my export setting is vimeo720p in media encoder..
  • Ludmil Kazakov
    October 25, 2016 at 12:43 am
    yes but in my case its MXF video and audio.. the mp3 music around it was converted to wav.. so thats weird.. it happens on clean audio with no score under it
  • Tero Ahlfors
    October 25, 2016 at 9:47 am
    [Ludmil Kazakov] “clean cache?”
    Might help?
  • Ludmil Kazakov
    October 30, 2016 at 4:10 am
    yes.. cleaned it.. found the problem.. there is a glitch with older version premiere where it generates a loop certain audio
