Activity Forums Adobe Premiere Pro Audio glitches on export in Media Encoder
  • Audio glitches on export in Media Encoder
    Posted by Dan Nastro on April 9, 2014 at 3:03 pm
    I notice when I export a video I will occasionally get audio glitches at certain parts of the piece, the spots of the glitches remain constant regardless of how I export or how many times. Also, certain audio music beds will loop and cause for cuts that are way off tempo (and aren’t present in the actual timeline).
    Strangely enough, when I export the video within Premiere it all exports fine. While this is a good temp workaround, it’s frustrating that I have to stop work and I can’t batch export. Anyone have any idea what could be the problem?
    Driss Devadip replied 5 years, 9 months ago 5 Members · 4 Replies
  • Vince Becquiot
    April 9, 2014 at 4:58 pm
    Hi Dan,
    Make sure you install the latest updates, there was a bug in 7.1 that would cause glitches on audio transitions.
    Also, I still avoid Mp3s, I convert them to Wav in Audition prior to import.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Greg Leslie
    April 9, 2014 at 5:55 pm
    I get a similar problem in PP 7.2.1 — some audio clips will stutter at the beginning of the clip, 8 or 9 repetitions about a frame apart. Only when queueing the renders out to AME.
  • Adam Derstine
    October 16, 2014 at 4:25 pm
    I’m having the same issues – random audio glitches. Some in .aiff files directly from a VO person. Render and replace audio has no effect. Deleting common folders and preview files has no effect. (Would appreciate help making sure I’ve found all common folders in w8.)
    Is there no solution to this? I’ve run into it several times but this is the worst. It’s a sequence with a variety of media, several downloaded youtube files, etc. I know that’s not ideal (trust me) but there is no good reason to have premiere unable to export clean audio from an .aiff!
    i7-3930k
    Windows 8 (yes, it’s a silly OS)
    GTX 570
    SSD for OS, Hardware RAID for media
  • Driss Devadip
    November 28, 2020 at 2:05 pm
    hello, make composition duration larger than work area
    (if it still doesn’t work, make composition duration even larger)
    it fixed my audio glitch in after effects and media encoder
    good luck
    youtube.com/archiproportion
