Activity Forums Adobe Premiere Pro Audio Glitch in Premiere Pro
  • Audio Glitch in Premiere Pro
    Posted by Michael Scarn on August 8, 2014 at 2:41 pm
    Check it.
    I had a mixed up, mangled up audio mix that was balanced but was getting a little outrageous in terms of editability. So I nested the audio and used that nested audio sequence to put the final touches on a few cuts, and then added som transitioning (crossfades/ volume automation).
    On the crossfades, I am getting strange glitching– a jackhammering effect. As the sound plays, a computerized ticking occurs, or a loud pop (thought I burst my eardrum at one point). What am I doing wrong?
    _________
    Premiere Pro CC
    iMac 3.5 GHz i7
    32 GB 1600 MHz DDR3
    Jp Pelc replied 12 years, 1 month ago 4 Members · 4 Replies
  • Paul Neumann
    August 8, 2014 at 3:42 pm
    I’ve had some kinks in my audio over the years, but nothing like that.
  • Jeff Pulera
    August 8, 2014 at 5:40 pm
    Not a big nesting fan – why not just export the audio as a new audio clip and then use that for the final mix? Simplifies what you’re asking Premiere to do all at once.
    Jeff Pulera
    Safe Harbor Computers
  • Michael Scarn
    August 8, 2014 at 5:41 pm
    Not a bad idea. Seems like a hassle, but I can do this. I’d still wonder the cause of the glitching, however.
  • Jp Pelc
    August 11, 2014 at 1:57 pm
    I experienced the same problems very recently with Premiere CC 2014 on OSX 10.8.5. I have never really solved it, all I know is that it happens sometimes and sometimes it doesn’t. Either way, it hasn’t shown up on the final render
