Activity › Forums › Panasonic Cameras › Audio Glich on Both Channels – at the same time???????
  • Audio Glich on Both Channels – at the same time???????
    Posted by Alexander Cullen on May 28, 2010 at 3:04 am
    I had a shoot 2 days ago using my HPX170. I ran a Senn Lav into one channel and a Rode shotgun into the other.
    Prior to the shoot, I tested the room and picked a clean frequency. Once the shoot began – a presentation, there were moments of distortion coming through the lav. They would last from 1/2 a second to a second and garble the audio.
    I assumed that there was interference in the air or that it had to do with the distance between the transmitter and the receiver.
    Sitting down to edit the material, I have discovered that this glitch is on both channels. When the lav distorts, the shotgun looses volume (about 5 db).
    I have never experienced an issue like this with my shooting set-up, which I have used regularly for over a year.
    All batteries were new and the camera battery was fully charged.
    Any ideas to help troubleshoot this mystery would be great.
    Thanks.
    Alex
    John Fishback
    replied 16 years, 4 months ago
    3 Members · 2 Replies
  • Jeremy Garchow
    May 28, 2010 at 1:36 pm
    Completely turn off the lav track, still have distorted boom?
  • John Fishback
    May 28, 2010 at 10:00 pm
    It’s possible something in the building emitted a strong emf pulse. It could have been a spark or a transmitter of some sort. Sennheiser has a very helpful chart of frequency use by city. In the future, you can check that list for clear freqs in your shooting location.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
