Activity Forums VEGAS Pro Audio Gain
  • Audio Gain
    Posted by Roger Bansemer on March 15, 2013 at 2:19 pm
    Sorry to be so full of questions today…
    We’re planing on doing some air travel and bringing our large camera is not practical.
    However, when using our XLR mikes on the small cameras, there is no way to shut of the automatic gain control so we end up with something like this where the audio builds when not saying anything indicated by the arrows.
    Is there any way at all in solving this problem. iZotope denoiser won’t take it out because of the accelerated volume. Using a volume envelope could be the answer but is there anything better?
    Roger Bansemer
    Roger Bansemer replied 13 years, 6 months ago 4 Members · 6 Replies
  • Graham Bernard
    March 15, 2013 at 6:11 pm
    [Roger Bansemer] “there is no way to shut of the automatic gain control”
    What camera is that?
    G
  • Bob Peterson
    March 15, 2013 at 6:29 pm
    Yes, there is. Take along a Zoom H4N. It can handle XLR mics, and can record in at least two formats (MP3 and Wav) at several different levels of precision and sampling frequency. Your camera should also record the audio to give you the ability to synch the Zoom’s file to the camera’s video. I do this as standard procedure, and it works like a charm.
  • Roger Bansemer
    March 15, 2013 at 6:46 pm
    There’s small Sony cameras that have no ability to change the automatic gain. But… I do have a really nice Sony recorder I could use if placed close enough to the interview. Not as good as using an XLR but probably the next best thing.
    Thanks.
    Roger
    Roger Bansemer
  • Roger Bansemer
    March 15, 2013 at 7:20 pm
    Wow! I just looked on my Sony PCM-D50 recorder and it does have the ability to put in an XLR mike. Great!
    My two small camera’s are an HRD RX520 and then a HDR CX160.
    Roger Bansemer
  • Colin Morris
    March 17, 2013 at 1:14 am
    Hi Roger,
    As mentioned with the Zoom recorder, you should be able record the input on the D-50 and use the line out or headphone out to feed the camera audio input. This gives you a double system. You would still plug your headphones into the camera, so you can monitor. I do it all the time with tascam recorders. I have found that the recorder output does not cause the camera auto gain to kick in very much. Another useful tip is to record one channel hot and one low on the recorder so you have a margin of audio level safety. Some recorders have that feature built in.
    Colin
    Colin Mendez Morris
    ArsMusica
    http://www.arsmusica.ca
  • Roger Bansemer
    March 18, 2013 at 10:13 am
    Hi Colin,
    Thanks for the info. I think that will work out fine.
    Roger Bansemer
