Activity Forums Apple Final Cut Pro Legacy Audio FX Filters…
  • Audio FX Filters…
    Posted by Spacedisco on July 25, 2005 at 2:46 pm
    Hi
    I’m wondering if there are any additional audio FX plugin filters you can get (for any version of FCP) but specifically for FCP 5 since i’m using that now. Far as I know there aren’t, only visual but not audio.
    curiously, SD
    Spacedisco replied 21 years ago 2 Members · 2 Replies
  • Arnie Schlissel
    July 25, 2005 at 4:13 pm
    FCP 4 & 5 will both accept some Audio Units filters. There aren’t as many AU filters as there are VST filters, but they certainly cover all of the basics & all of the most popular effects. You will not get the cute UI that makes a lot of these filters easier to use, however, just the same generic UI that FCP’s built in audio filters use.
    I found a pretty good selection of plug ins here: https://www.hitsquad.com/smm/mac/PLUGINS_AU/
    Arnie
    https://www.arniepix.com
  • Spacedisco
    August 7, 2005 at 7:19 pm
    thanks for the help, tried downloading a couple, actually what I meant was a FCP audio FX plugin that you just drag (or import) into the FCP plugins folder and ‘boom’ ya’ got it! Opposed to learning any new software or functions or anything.
