Activity › Forums › Apple Final Cut Pro Legacy › audio from Protools goes out of sync
Posted by Steve Harrington on July 5, 2008 at 10:33 pmI have these aiffs I’ve received from Pro Tools and the audio seems to gradually go out of sync. The audio waveforms also do not correlate to what is being heard. When I drag them onto my 24 frame timeline I get a green bar along the top which I believe is associated with a speed filter. Which would make sense. If these files are dragged onto a 23.98 timeline (a different frame rate) no bar appears. So something seems to be wrong. The guys working with the Pro Tools cant seem to figure it out either. Has anyone run into this issue?
Steve Harrington replied 18 years, 2 months ago 3 Members · 8 Replies -
David Scott
July 5, 2008 at 11:52 pmHi Stephen
Try checking that the bit rate is the same, ideally you should both be working 24bit audio. Pull down the sequence menu, select settings, and check that your audio rate is 24bit at 48hz. The AIFF from Protools should have the same settings (which you can check in your browser). If they are different, remove the audio from the sequence, change the sequence settings to match it, then put it back on – that should fix it.
Hope that works
God blessDavid Scott,
Senior Editor,
GOD TV (UK) -
Sean Oneil
July 6, 2008 at 7:45 am[Stephen Franciosa] “When I drag them onto my 24 frame timeline I get a green bar along the top which I believe is associated with a speed filter. Which would make sense. If these files are dragged onto a 23.98 timeline (a different frame rate) no bar appears.”
This is a new “feature” in Final Cut. Final Cut does not actually know what speed the audio is supposed to be (24.00 or 23.98). So when you import it, it just assumes that whatever your Easy Setup is, that is what speed the audio is supposed to be. This problem also occurs with PAL stuff.
Remove the audio files from your project. Save and quit FCP. Now relaunch and change your Easy Setup to something that is 24.00fps (not 23.98). Now import the aif files. You’ll now see the exact opposite. On a 23.98 sequence you’ll get a green bar, but on a 24.00 sequence it will be fine. Since what you tried is out of sync, I would assume the Pro Tools audio is supposed to be 24.00.
Sean
Steve Harrington
July 12, 2008 at 5:40 amWell the Easy setup, solved the issue, but now it seems my audio which has been in the project already has a green bar and is drifting out of sync.
Sean Oneil
July 13, 2008 at 7:51 pmDo whatever Easy Setup you need to bring one piece of audio in so that it syncs. Once it syncs, export a Quicktime movie with video and audio.
Open that new Quicktime movie in Cinema Tools. You can then conform it to 23.98 or 24.00. Now when you import this new file in FCP, it will be recognized as that framerate no matter what Easy Setup or sequence setting you use.
Sean
Steve Harrington
July 15, 2008 at 8:05 pmFantastic, your a life saver. One problem, I have production audio now which has a green bar above it which I cannot remove to reimport. I cant remember if it was like this before my other audio issues started, How can I fix this?
Steve Harrington
Sean Oneil
July 15, 2008 at 8:29 pm[Stephen Franciosa] “I cant remember if it was like this before my other audio issues started, How can I fix this?”
I’m sorry to tell you this but I have no idea. There’s no way to “Remove Attributes” in this case unfortunately. When I first discovered all this odd behavior, I sent feedback to Apple.
All I can suggest is maybe try to make it offline, change Easy Setup, save quit and restart FCP, and then reconnect the media.
Sean
