Activity › Forums › Avid Media Composer › audio from 29.97 aiff into 24p timeline
  • audio from 29.97 aiff into 24p timeline
    Posted by Per Scaffidi on March 16, 2010 at 7:19 pm
    Hi all,
    Just had a new 1080p transfer done from film to HDCAM SR with a 5.1 soundtrack. We have a stereo aiff file exported from our original standard def 29.97 version of the same film. My question is: once I get the HDCAM SR dubbed to a format I can work with (probably DVCPRO HD) can I then drop the aiff audio into a 1080p sequence with the DVCPRO HD dub? Will it sync? Is audio dependant on framerate? Thanks!
    Per Scaffidi replied 16 years, 6 months ago 3 Members · 3 Replies
  • Job Ter burg
    March 16, 2010 at 8:01 pm
    If it’s just an AIF or WAV, and it is 48.000 samples/second, that’s what matters. Audio does not really have a framerate (although it can have one within the Avid), and 48K should remain 48K.
  • Michael Phillips
    March 17, 2010 at 12:52 am
    It will sync with a 23.976 dub of the 1080, not 24.000. You will need to pull it up (speed up) by .1% to stay in sync.
    Michael
    Michael Phillips
  • Per Scaffidi
    March 17, 2010 at 1:49 am
    So are you saying that it will sync to 23.97, but to sync to 24 I would have to speed it up?
