Activity Forums Apple Final Cut Pro Legacy Audio for playback
  • Audio for playback
    Posted by Lawrence Gray on March 30, 2010 at 6:30 am
    I’ve no idea why this has started happening. I’m editing a project and for some reason every time I change anything on the time line I have to re-render the Audio “For Playback.”
    This takes about two seconds each time but why does it do this and why isn’t it rendered automatically for playback?
    John Fishback replied 16 years, 5 months ago 2 Members · 3 Replies
  • John Fishback
    March 30, 2010 at 9:50 pm
    What’s your audio sample rate? Where did the audio come from – what kind of camera and what codec was shot?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Lawrence Gray
    March 31, 2010 at 7:46 am
    I’m using a PMW EX1. Never had this problem before. Except I’ve upgraded to Snowleopard in between, which has made my machine much faster so I can’t see that as the reason for this.
    I’ve been using the nesting function a lot on this edit as I’ve tested various edits, which has caused plenty of crashes. So perhaps that is a culprit. However, in theory that shouldn’t cause problems with the bottom level.
    Previously I’ve been able to use many different sound tracks on the time line without having to render all the time to play back the audio. Can’t I just set it to render for playback automatically? It seems such a pointless thing to have to do.
    48khz, XDCam 1080 25p setting for transfer.
    Lawrence Gray
  • John Fishback
    March 31, 2010 at 3:20 pm
    As I haven’t upgraded to SL, I can’t comment on whether that’d be a factor. Most folks don’t seem to be having problems with it as long as they did a clean install. I know the EX1 records audio properly. Do you have any music or SFX tracks in your timeline? Are they 48kHz? Also, with a lot of tracks there does come a point where you need to render even if all the audio is 48kHz 16 or 24 bit.
    John
