Activity Forums Adobe Premiere Pro Audio follows video in Multicam ????
  • Audio follows video in Multicam ????
    Posted by Herb Sevush on March 10, 2014 at 6:27 pm
    The following comes from Adobe’s documentation – “Using the Multi-Camera Source Sequence dialog box”
    In the section about choosing how to set-up the audio, one of the choices is to select “Switch Audio.” I’m trying ot understand what this choice does. Here is Adobe’s explanation –
    “Select Switch Audio when you want the audio to switch with its linked video. This setting unmutes all audio. It enables multicam editing on both the video and audio of the source sequence, when the audio follows video setting is enabled in the Program monitor. This setting also maps multi-mono source audio into a single adaptive audio track.”
    Since I need to switch audio between my different camera’s as much as I need to switch the video this looks like the choice for me, however I have no idea what “maps multi-mono source audio into a single adaptive audio track” means. Can anyone clarify, because the manual does not.
    Also, it sounds like I can switch audio by using the “audio follow video” feature, but is it possible to switch audio without switching the video ?
    Thanks.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
    Herb Sevush replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
