Activity Forums Apple Final Cut Pro Audio fluctuated during multicam switching on the original footage
  • Audio fluctuated during multicam switching on the original footage
    Posted by Sam Lee on March 25, 2016 at 11:03 pm
    I’m noticing a very annoying problem/bug in the latest ver of FCP 10:
    The audio would fluctuate whenever I switch the angle. It occurred with 2, 3, 5 angles. This only occurs when the sound recorded into the camera. You can clearly hear it during quieter interview segment. This doesn’t occur when I have a separate audio recorder .WAV file.
    A closer analysis revealed that I have the background noise and hum filter applied globally. Hmm. When I uncheck those filters, it’s no longer there. So something’s not right with these filters.
    David Powell replied 10 years, 5 months ago 2 Members · 1 Reply
  • David Powell
    March 30, 2016 at 3:11 am
    You can’t do audio filters in the nest or you’ll get noise at every cut on your timeline. You can only do video level corrections in the nest without interruptions.
