Activity › Forums › Apple Final Cut Pro Legacy › Audio fix to entire sequence
  • Audio fix to entire sequence
    Posted by Arturo Glass on August 31, 2008 at 5:13 pm
    I’ve adjusted the peaks so nothing goes over 0db in a sequence. The sound ranges from around -18 to -6. Is there a way I can run a filter or modifier across the entire sequence in order to shift all of these levels so they all stay between -3 and -6? That is, a way to make the sound overall but without running into peaking issues.
    Stephen May replied 18 years, 1 month ago 3 Members · 4 Replies
  • Andy Mees
    September 1, 2008 at 1:10 pm
    those levels are pretty high .. are you really sure you want to do this? I would be looking at bringing the peaks down not pushing the overall levels up
    to answer your question, you can use the Compressor/Limiter filter to compress the dynamic range of the audio whilst simultaneously boosting the level if necessary
  • Arturo Glass
    September 1, 2008 at 2:40 pm
    What sort of levels are optimal then? Project includes interview footage, field shoot, music, sound effects… overall mix level should be in what range?
  • Andy Mees
    September 1, 2008 at 3:10 pm
    Thats a little subjective Arturo, and a lot depend on your distribution path. Is this for broadcast? You’ll likely get a wealth of ardently defended opinion … my own personal preference is a line up level of -20db with absolute peaks no higher than -12db
  • Stephen May
    September 1, 2008 at 9:57 pm
    Audio Fix for Entire Sequence:
    Create a new sequence. Drag your existing master sequence into this new sequence. Go to MARK > AUDIO PEAKS > MARK. Audio peaks are detected on your timeline. Double-click your master sequence to make necessary changes. Go back to the new sequence and go to MARK> AUDIO PEAKS > CLEAR.
    Now check the sequence again.
    Stephen May
    Keystone Media Productions
    Freelance Videographer
