Activity Forums Apple Final Cut Pro Legacy Audio filter to create a ‘retro’ sound
  • Audio filter to create a ‘retro’ sound
    Posted by Martin Robbins on February 21, 2012 at 3:42 pm
    Hello,
    I’m an FCP 7 editor but very in-experienced when it comes to sound. I have never used Soundtrack Pro. I want to create a voiceover with a retro feel. To get a sound such as
    https://www.youtube.com/watch?v=bcg53bRktCg
    If anyone knows how to do this, could you describe it in layman’s terms please?
    Andrew Rendell replied 14 years, 7 months ago 3 Members · 2 Replies
  • Jean-christophe Boulay
    February 21, 2012 at 6:29 pm
    Hi Martin,
    An equalizer with a high-shelf filter cutting higher frequencies will get you partway there. A touch of distortion or saturation on top of that should get you in the ballpark. You can play with the EQ frequency and gain cut to get the tone you like best and only use a bit of soft distortion, don’t go overboard. This should be inserted after whatever normal mixing treatment needs to be applied to the voice over, such as normal EQ and compression.
    I don’t have any experience with STP and positively hate working with audio in FCP, so can’t advise much on specific plugins to use. The default system AU plugins “AUHighShelfFilter” and “AUDistortion” should be able to get you there if that’s all you have available. There are also more focused and professional (and expensive) tools, such as Audio Ease’s Speakerphone, which is probably a bit much for your current needs.
    IHTH
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Andrew Rendell
    February 21, 2012 at 10:25 pm
    It’s an overdriven analogue recording. To match it you’ll need:
    Hard compression (10 or more in the ratio), or a limiter (drive the signal into it at high volume so that it’s constantly reducing the level).
    Distortion (just a little).
    Probably a noise gate (or take a razor blade tool and cut out the quiet bits in between the words/sentences).
    For the sections with reverb, I’d suggest a “plate” emulation to get that old style vibe.
    A continuous loop of low level hiss would probably help as well.
    Add the effects one at a time and adjust each one to find the “sweet spot” before you add the next one.
