Activity Forums Apple Final Cut Pro Legacy Audio Filter to Correct Music Distortion?
  • Audio Filter to Correct Music Distortion?
    Posted by Daniel Monskey on May 28, 2009 at 9:48 pm
    I have a music track that was recorded live a bit too loud. There is distortion. Is there a filter that I can use to try and reduce the distortion level? What settings should I focus on to change?
    Dan
    Daniel Monskey
    John Fishback
    replied 17 years, 3 months ago
    3 Members · 2 Replies
  • David Bogie
    May 28, 2009 at 10:09 pm
    Digital distortion cannot be corrected. you can mask it by applying more noise but, sadly, it’s rather like trying to recover image pixels from a terribly overexposed scene. There just isn’t data in your file, it’s all been crushed.
    Umm, that’s what I think I know. Hopefully someone will come by with a creative solution of which I am ignorant.
    bogiesan
  • John Fishback
    May 29, 2009 at 1:50 pm
    Checkout iZotope RX. It has a de-clipper module. Depending on the amount of clipping it can help. Listen to the de-clipping example on the home page.
    https://www.izotope.com/products/audio/rx/
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
