Activity Forums Apple Final Cut Pro Legacy Audio Filter
  • Posted by Neil Gregory on July 24, 2007 at 9:11 am
    I am editing a speech in a church and the sound has a lot of bass and echo. I have tried a high pass filter with a low cutoff frequency but it hasn’t really helped. The words are being lost in the low frequency stuff still.
    Does anyone know what filter and settings might solve this problem?
    Many thanks in advance.
    Neil
    John Fishback replied 19 years, 1 month ago 3 Members · 3 Replies
  • Michael Gissing
    July 24, 2007 at 11:58 pm
    You need both a high pass and a parametric or notch style filter. Rooms have resonances that amplify certain frequencies. Find that frequency by first adding + gain with a notch Q around 10. (Q is the width of the notch. The lower the Q the wider the frequency band being affected.)
    Trim the frequency up and down until you hear the resonance amplify. Trim – gain to taste. There may be a secondary or harmonic resonance. If the primary resonance is around 120hz (very common frequency in large buildings)then it is likely that a harmonic resonance may occur at 240hz and possibly 480hz. Once you find the low primary resonance try a second notch at double the primary frequency. It is always easiest to tune in to resonance by + gain, then trim -.
  • Neil Gregory
    July 25, 2007 at 7:49 am
    Thanks for that- Fantastic advice
  • John Fishback
    July 25, 2007 at 8:40 pm
    Try removing noise using Soundtrack Pro. That might help a lot.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
