Activity › Forums › Adobe Audition › audio files not saving in AA 1.5
  • audio files not saving in AA 1.5
    Posted by Wyatt06 on September 24, 2006 at 8:18 pm
    When I edit files in Audition 1.5 and ‘save’ the file, I watch the blue bar for a minute or so while it saves the file..what I just found out is that for some weeks now all my editing was not saved at all.
    I activated the software when I first installed it.
    This morning I went to ‘add/remove programs’ and repaired the software. Then brought up a file and hard limited it…saved it..brought it back up, and nothing is being saved.
    I just lost months of work and am really bummed.
    If anyone can help me sort this out, I’d really appreciate it.
    Thanks in advance,
    Wyatt06
    Wyatt06 replied 20 years ago 2 Members · 5 Replies
  • Willie Toth
    September 24, 2006 at 9:20 pm
    Wyatt,
    In all the years I have been using this program I have never seen this problem before … I would check all your file paths and I would do more than just do a repair, I would completely uninstall and reinstall … Let us know what you have found … WILLIE
  • Wyatt06
    September 24, 2006 at 10:05 pm
    I will try that. There’s one other possiblity that ocurred to me:
    Previous to installing 1.5 I had the tryout version. I removed that before installing 1.5, but am
    wondering if there might have been something left in the registry that could cause a problem?
    Its going to take days to go back and determine exactly when it stopped working. I have been archiving
    speech tapes onto CD and have not had the occaision to go back and listen to each CD comparatively. Looks
    like I will have to now.
    Meantime I’ll reinstall and at least see if this will begin to work properly again.
    Thanks for your reply,
    Wyatt
  • Wyatt06
    September 25, 2006 at 12:11 am
    WILLIE,
    I removed it from my system and did a fresh install. No change to report, and that surprises me a lot.
    It is using a secondary temp file as it should, and I have no plug-ins associated with it.
    The installation did not prompt me to register with Adobe.
    I have not had a problem recording, and as recently as a month ago I recall making changes on an
    original recording that did save and burn to CD.
    It will take some time to find exactly when this problem began, and whether recordings I made last January and worked on in, say April or later are any good or not.
    This has been a real downer for me, and I do appreciate your response,
    Wyatt
  • Willie Toth
    September 25, 2006 at 10:40 am
    Wyatt,
    I can totally relate to your delema I have lost hard drives before and hours worth of work … The reason Audition didn’t promt you to register is that it remembers the info … If I were you I would not only uninstall from the add and remove programs but next I would do a search for any files and folders relating to Audition and delete those as well … I think you are right that something is lingering from the demo … Let me know what you find out …….. WILLIE
  • Wyatt06
    September 26, 2006 at 7:26 pm
    Latest:
    I uninstalled aa1.5 again, and this time ran a registry cleaner before reinstallation. Program installed, but never prompted me to register.
    After 3 days of trying without success to initiate an email with tech support, and 2 days of not being able to get through to anyone via telephone, I checked my acount and it doesn’t show *any* products registered to me. Telephone says my customer # isn’t in their system, [and I have that on a printout I did months ago from them].
    So I am at a loss for now. I guess their new system upgrade must have them swamped with calls.
    I’ll keep trying, but I have spent the last 3 days on this and am running out of gas.
    Wyatt
