Activity Forums Apple Final Cut Pro Legacy Audio File Question
  • Audio File Question
    Posted by Bob Delano on December 3, 2005 at 4:35 pm
    I just completed the voice over audio track for a short projct – about two minutes – and need to send it off as an AIFF or WAV file to another shop. What recomendations are there to keep the quality OK but the file size small. It’s just a single narration, and as a Linear PCM file, 48k, mono, it’s about 10 meg. I’d like to shrink the file size a bit…
    Gunleik Groven replied 20 years, 9 months ago 4 Members · 3 Replies
  • Don Greening
    December 3, 2005 at 5:02 pm
    You could run it through A.Pack and compress it to the 192 bit rate setting. That’ll drop the file size to around 1 meg instead of 10. You’ll end up with the DVD audio standard of an .ac3 file format. A.Pack shipped as a stand alone app with Compressor 1 and it’s now part of Compressor 2.
    – Don
  • John Fishback
    December 3, 2005 at 5:22 pm
    If you zip a 10 Meg file it should shrink it to about 8.4 Megs. It’s not a lot, but if you need to deliver aiff or wav, I think it’s the best you can do.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
  • Gunleik Groven
    December 3, 2005 at 5:27 pm
    10 Mb is allready small!
    If you cannot mail through your ordinair account, use:
    https://www.yousendit.com/
    Gunleik
