Activity Forums Audio audio field recorder for doco
  • audio field recorder for doco
    Posted by Nicholas Canavan on June 27, 2011 at 6:40 am
    Hello to everyone.
    I have been filming an independent doco film for the last few years. My camera is the Sony Fx1e. For audio i have been using the marantz pmd660 with a Rode NTG2 shotgun mic.
    I have had many troubles over time with the marantz, and have previously talked about these in old posts on the forum.
    So now i am fed up with it, and want to buy a new audio field recorder.
    From researching it sounds like the zoom h4n may be ok…there also seems to be many more in the same price range. But i don’t know if this will suffice for what i want. The doco is on the move sometimes, others its a sit down interview type thing.
    It seems that for audio recorders it is either the $200-500 price range, or stepping up to the very expensive recorders.
    My budget really can’t step up to the recorders for $2000, $3000…unless there is a super good reason to invest that much money.
    Any help/advice would be greatly appreciated.
    Nick.
    Ty Ford replied 15 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Al Bergstein
    June 27, 2011 at 9:53 am
    R u working with a sound eng or is it just you alone?
    What mics r you using? Xlr?
    Tascam h2p2 is pretty sweet, around $800.
    Read this too..
    https://www.martin-doppelbauer.de/fieldrecorder/distortions.html
    Edirol is superb at around $1k.
    Alf
  • Nicholas Canavan
    June 27, 2011 at 11:29 pm
    Hi Al
    I have been working with a girlfriend of mine for the last few years..
    She started with little experience, but over time has learnt the basics of recording and knows the marantz well. I now call her my sound recordist…not a pro, but she is doing pretty well with alot of practice.
    Yes the mic is a Rode NTG2, xlr input into the marantz.
    I will have a look at the tascam and edirol too…
    I have read the link you gave, though it is very technical i think i can understand the gist of it. Basically it is saying that a hot signal going into the zoom h4n even with the zoom turned down will still distort? (sorry for my lack of knowledge here)..
    I am a little worried, as my doco is filming a hip-hop artist, and when he does live shows, i need to get a feed from the live desk into my audio recorder for a recording of the show. (the marantz was a nightmare for this).
  • Ty Ford
    June 28, 2011 at 12:32 am
    Hi Nick,
    How many tracks to you expect to need?
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Nicholas Canavan
    June 28, 2011 at 1:02 am
    Hi Ty, most likely just the 1, since i am using just the 1 input from my rode ntg2 mic, xlr input.
    Possibly use 2 when getting a live feed from a desk at a live music show..as it could be a left and right xlr ins to the recording device.
    When or in what situations would call for more inputs? just out of curiosity?
  • Ty Ford
    June 28, 2011 at 1:11 am
    OK,
    When shooting a music video, you might want anything from a full multitrack feed from the console (16-to 24 tracks) plus live mics to recreate the sound the audience is hearing from the stage
    You might want groups tracks, lead vocal, stereo instrument submix, stereo live mics.
    You might want 4 tracks, as i’m doing this week for a three mic interview show. Each mic goes to a separate track and the 4th track is a mono mix of the three tracks. We’ll use the mono mix unless I blow it somehow and then we have the isos to fix things.
    Dialog scene or wedding video. Bride on one, groom on two, preacher on three.
    Regards,
    Ty ford
  • Al Bergstein
    June 28, 2011 at 4:54 am
    I do sound off the boards a lot, the edirol is my choice though the tascam is a close second.
    I don’t use the zoom for line feeds, if i can help it. I do always try to use my mixpre.it’s worth the money.
    Alf
  • Nicholas Canavan
    June 29, 2011 at 2:48 am
    Al, what is the main reason that the zoom lacks in situations getting feeds from sound boards? Just overall quality? distortion?
    So you would normally use a mixer in between the board and your recorder just to get a better overall sound?
  • Nicholas Canavan
    June 29, 2011 at 2:52 am
    thanks ty for your response.
    Since i currently have only 1 mic, i guess its less likely i will use multi-tracks. However i have been thinking about wireless lav mics..as well as the shotgun rode ntg2 for recording.
  • Al Bergstein
    June 29, 2011 at 5:41 am
    Nicolas, the zoom does not support true line in. You can easily search to find this well documented. You need to pad it, at best. Put a mixpre in front of it and you will be better off. This is the easiest way to explain it quickly. Search around for more detail, that’s what i did.
    Alf
  • Ty Ford
    June 29, 2011 at 11:27 am
    Hello Al,
    Are the Zoom H4n inputs -10 consumer line level?
    That would make them between mic level and pro line level.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
