Activity Forums Apple Final Cut Pro Legacy audio fade – PLEASE HELP
  • audio fade – PLEASE HELP
    Posted by Jason Spencer on June 18, 2009 at 4:25 pm
    Hi all,
    I’ve been on an Avid for a while and now I’m back on FCP. I’m trying to get my skills and speed on FCP to what it is on Avid. I’m missing a few things that I’m hoping someone cane help me out with.
    When I’m making an audio dissolve I want to START the dissolve at the end of one clip and go (let’s say) 20 frames into the next clip. When I do that on FCP it appears to only allow me to do a cross dissolve with 10 frames on either side. I see that when I double-click I can change the duration, but not where the dissolve starts and ends. I can control it on a video dissolve. What gives?!? Am I missing something? Any help would be appreciated.
    By the by, I’m on FCP 6.0 on a G4 Powerbook.
    John Fishback replied 17 years, 3 months ago 3 Members · 2 Replies
  • Dennis Leppell
    June 18, 2009 at 4:56 pm
    I agree, the audio transition control could be beefed up a bit. In your case, use the slip tool to align the transition to your liking….hit S once is the keystroke you’re looking for.
  • John Fishback
    June 18, 2009 at 7:45 pm
    If the dissolve is limited, it’s probably because one side of the transition only has (in your case) 10 frames of audio before the clip ends.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
