Activity › Forums › VEGAS Pro › audio fade help
  • audio fade help
    Posted by Sim8888 on June 28, 2007 at 6:10 am
    Hi All,
    Probably an easy one, but am new to vegas, so bare with me…
    The normal audio fades raise the volume from 0, is there any way that i can fade the volume from full volume to a 0, so just ‘flipping’ the fade curve to start from the top corner? am sure there is, i just can’t find it
    cheers
    simon
    Sim8888 replied 19 years, 3 months ago 3 Members · 3 Replies
  • Mike Kujbida
    June 28, 2007 at 11:14 am
    I’m confused here with what you’re trying to accomplish.
    The normal audio fades raise the volume from 0…
    That’s normal behaviour for a fade-in (at the beginning of a clip).
    …fade the volume from full volume to a 0…
    That’s normal behaviour for a fade-out (at the end of a clip).
    Try experimenting with volume envelopes to see if this is what you’re looking for.
  • Don Bloom
    insert an envelope into the clip adjust away. “V” will insert, right click on the track header will also give you a choice to insert a volume envelope.
    Add Points and adjust.
    Don
  • Sim8888
    June 29, 2007 at 12:56 am
    Thanks for the tips guys, much appreciated.
    Don, your tip helped greatly, different way as to how i thought it would be done, but achieved the exact effect i was looking for.
    Mike, i basically had a soundtrack split into 3. Section 1 & 3 to be full volume, but the middle section to start at full volume, but to quickly “fade” down to half volume, and then fade back upto full volume for the start of section 3….hope that made sense!
    thanks again for the help
    simon
