Activity › Forums › Apple Final Cut Pro Legacy › Audio fade HELP SOS!
  • Audio fade HELP SOS!
    Posted by Carolina Luna on September 9, 2008 at 11:32 am
    Hi all…
    I am trying to do some audio fades in the tracks of my edit line but the slope of the gain is not straight… it seems to go down in a curve which makes the audio drop suddenly and not fade slowly until it dies… ANY ADVICE??? I am sure it can be done but can’t find the way.
    Cheers.
    Stephan Walfridsson replied 18 years ago 2 Members · 1 Reply
  • Stephan Walfridsson
    September 9, 2008 at 12:55 pm
    Are you usig normal Crossfade ‘dissolves’ or keyframing the gain curves?
    If you are using Crossfades ctr-click/right-click on your fades and change from Crossfade (+ 3dB) to Crossfade (0dB). This sometimes does the trick for me. If it doesn’t help then remove the crossfade, enable keyframe overlays in the timeline settings and try keyframing the gain curve…
    /Stephan
