Activity › Forums › Apple Final Cut Pro › Audio Extend edit bug?
  • Audio Extend edit bug?
    Posted by Jiri Fiala on April 16, 2012 at 3:35 pm
    Hi!
    moving audio edit points is very buggy for me. Try this please:
    1) Insert any clip with audio and video into timeline
    2) slice it with cmd-b
    3) select both resulting clips and expand audio with ctrl+s
    4) select audio edit with shift-
    5) move skimmer and extend audio edit shift-x
    6) repeat step 5 with random skimmer locations.
    Sometimes it works, sometimes it doesn’t. It’s not an issue with media handles or such.
    Bret Williams replied 14 years, 5 months ago 2 Members · 1 Reply
  • Bret Williams
    April 16, 2012 at 4:54 pm
    I’m finding the results predictable. If you extend the length beyond the video, you can shift-x again to shorten it no problem. But once you’ve shortened the audio in any fashion, shift-x will only shorten. It will no longer lengthen. It appears random, but those are the rules it’s following. Looks like a bug to me.
    Why can’t we simply select the in and out side of an audio edit and roll it while we’re at it. Trimming in this app takes about 3 extra steps from 7.
