Activity Forums Adobe After Effects Audio Export Settings
  • Audio Export Settings
    Posted by Jack Stewart on May 4, 2012 at 5:57 pm
    Hello
    My client has asked me to export it out with 128 bit audio at 22 hertz audio.
    I have chosen 22.050 KHz / 16 bit / Stereo. Is this correct?
    I don’t understand what the 128 bit audio setting is and how I check if this is correctly set in AE.
    Any help would be much appreciated.
    Many thanks,
    Jack
    Jack Stewart replied 14 years, 4 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 4, 2012 at 9:20 pm
    It’s not going to be WAV or AIFF, but it could likely be MP3 (MPEG-1 Layer III) or MP4/M4A (AAC).
    While you’re asking questions, you should confirm if they need stereo or mono.
    Walter Soyka
  • Jack Stewart
    May 4, 2012 at 9:29 pm
    Hey,
    Thanks for the replies guys. Yes, your right I should ask if its Stereo or mono. I think its likely to be Stereo. The file will be out putted as a MP4 video file for upload to the web. So no need to worry about that, but I always thought 48.000 GHz was the standard. I am not sure why they want it changed to 22.050.
    Can anyone suggest where the option to change it to 128 bit audio might be in AE or what that even means?
    Cheers,
    Jack
