Activity Forums DaVinci Resolve Audio Export guidelines for Amazon Prime
  • Audio Export guidelines for Amazon Prime
    Posted by Ben Dejong on June 10, 2024 at 10:46 pm
    I’m hoping someone here has either the knowledge or a resource for me to
    know what my audio export settings would be for a short film that is
    going to be uploaded to Amazon Prime. This is my first time prepping
    for a streaming service so I’m going in cold. There are no specs on
    Prime’s guidelines for audio such as loudness or peak. Only for the video file, captions, etc…
    So, common sense would indicate that I could use the same values for
    loudness and peaks as the Netflix standards which are listed in the
    Resolve audio loudness metering (as well as normalization options)
    export settings. But I wonder, because the difference between Netflix
    and YouTube is enormous. If anyone can guide me on this, it would be
    greatly appreciated. I guess it means you’re getting somewhere when the
    info you need isn’t just a simple YouTube tutorial search!
    Michael Gissing replied 2 years, 3 months ago 2 Members · 3 Replies
  • Michael Gissing
    June 11, 2024 at 8:35 am
    Prime should have tech specs for loudness and channel assignment published. My subjective experience is Prime is louder than Netflix. Prime probably uses the same SMPTE loudness standard as cinema and international broadcast which are all within +/-1db of LUFs. Netflix is a lower LUFs and they seem to be the outliers in the world of loudness, apart from the internet which is a dogs breakfast.
  • Ben Dejong
    June 13, 2024 at 6:12 pm
    Thanks Michael. The specs on audio are confusing. Do you know if I export a stereo audio mix as a single interleaved file, or separate L/R channels for these services? The terminology they used seems to leave a lot to interpretation.
  • Michael Gissing
    June 17, 2024 at 1:37 am
    I’d have to read their specs to answer specifics. If in doubt you should ask them
