Activity Forums Adobe After Effects Audio error w/quicktime imports
  • Audio error w/quicktime imports
    Posted by Andrew Potter on November 18, 2005 at 3:52 pm
    When I import a QT file with audio, when I render (preview and make movie) I get an audio error “After Effects error opening sound component (-2166)”
    The preview still plays with audio, and I get the error intermittently, but if definitely will not render as an output.
    Is there a better way to import a movie with audio?
    All this with:
    G5 w/2GB SDRAM; 2.7GHz
    QT 7.0.3
    AE 5.5
    QT mov w/Sorenson3; 48KHz (or 44.1; consistent w/AE comp)
    Stevev replied 20 years, 10 months ago 4 Members · 4 Replies
  • Steve Roberts
    November 18, 2005 at 3:58 pm
    I’ve found that AE doesn’t like importing Sorenson. Try Animation, Photo-JPEG or a TGA sequence.
    Steve
  • Andrew Potter
    November 18, 2005 at 4:08 pm
    Good advice, however I get the same results on audio files only, uncompressed.
  • Robert Morris
    November 18, 2005 at 5:55 pm
    I’ve gotten a similar error if my sound card is doing other things as well, such as playing MP3s, or even if I had opened up the Quicktime player and played a clip with sound while AE was open. I’m on a PC running Windows XP and my sound is just onboard Legacy drivers. Let me know if you solve your problem.
  • Stevev
    November 22, 2005 at 6:37 pm
    I am having the same problem.
    Still no solution over here.
    have you found an work around?
    The .AIF files I am importing and working with in AE are just
    16:44:1:none
    let me know
    stevev-
