Activity Forums Avid Media Composer Audio EQ problems
  • Audio EQ problems
    Posted by Bob Sykes on September 25, 2009 at 12:02 am
    When audio sweetening on AVID #1, I am using the mixer tool to adjust music levels and apply an EQ effect to “notch” out the mid-range frequency.
    When I move over to AVID #2, the music that I’ve meticulously adjusted under a VO or stand-up is much louder.
    The mixer level is identical (-15db) Even though I see the EQ effect and it’s rendered, it appears that my EQ settings are not being applied on the music clip.
    If I remove the EQ effect and put a new EQ effect on the clip, the music is still dramatically different than on AVID #1.
    EQ setting I’m using a -7.5db at around 3500hz.
    System
    MC 3.51 SDI Mojo
    Unity 5.1.2
    Mac OS 10.4.6
    Bob Sykes replied 16 years, 12 months ago 3 Members · 3 Replies
  • Job Ter burg
    September 25, 2009 at 10:14 am
    Is that a typo in your OS? Should be 10.5.5 or 10.5.6 or 10.5.7 for MC 3.5.1.
  • Ed Cilley
    September 25, 2009 at 1:49 pm
    Is your hardware in both rooms set-up the same?
    Settings>Audio Project>Hardware>HW Calibration (for example, -20 dBFS)
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Bob Sykes
    September 25, 2009 at 3:03 pm
    It is a typo. 10.5.6
    The rooms are exactly the same
