Activity Forums VEGAS Pro Audio Envelopes Not Fully Working
  • Audio Envelopes Not Fully Working
    Posted by Debbie King on December 8, 2013 at 3:56 pm
    Hello Everyone:
    I am in the process of balancing the volume between clips and when I envelope them some work while others do not work as efficiently. I find myself lowering the DB’s so to balance the volume to a very significant level and the audio is still not lowered enough. Has anyone had an issue like this? Is there another tool that I can use to make this happen more efficiently?
    Debbie
    Debbie King replied 12 years, 9 months ago 3 Members · 5 Replies
  • Steve Rhoden
    December 8, 2013 at 10:56 pm
    Never encountered an issue with the volume envelope in Vegas before.
    But an additional method you can try is placing the cursor at the
    top of your audio file on the timeline, and when it changes to a
    pointed finger, you can then drag down the Gain to your liking.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Debbie King
    December 8, 2013 at 11:10 pm
    Thank you Steve. I’ll try it.
    Debbie
  • Steve Rhoden
    December 8, 2013 at 11:23 pm
    ok.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Rofrano
    December 9, 2013 at 1:46 am
    You also might want to learn how to use the Track Compressor that is on every audio track by default. Compressors will raise soft sounds and lower loud ones which eliminates needing volume envelopes simply to smooth out your audio.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Debbie King
    December 11, 2013 at 12:08 am
    Thanks John. I’ll try it. What I ended up doing was using the FX function to raise and lower volume (Multi Band and Waveform)
    Many thanks,
    Debbie
