Activity › Forums › VEGAS Pro › Audio Envelope Points
  • Audio Envelope Points
    Posted by John Perez on November 12, 2017 at 2:27 pm
    Is there a faster way to delete/work with audio envelope points rather than right-clicking/delete?
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    John Norton replied 8 years, 10 months ago 3 Members · 3 Replies
  • Danny Hays
    November 12, 2017 at 4:12 pm
    You can delete or reset the envelope, and start over.
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
  • John Norton
    November 13, 2017 at 12:26 am
    If you “select” the audio envelope tool at the bottom, default is not selected, then by creating a time selection above the audio envelope points that are of interest to you, you can for example delete only those auto selected points.
  • John Norton
    November 13, 2017 at 12:43 am
    Couldn’t see how to edit my post.
    Meant to say that it appears that to un-select the envelope edit tool then select the normal edit tool.
    For example … With normal edit tool selected, envelope edit tool not selected, create a time selection, drag the audio envelope say down, within the selected area to auto create 4 envelope points. Now if you wantesd to delete these or any other points (besides ctrl-z) select the envelope edit tool, draw timeline selection and press the del key.
