Activity › Forums › VEGAS Pro › Audio effects not working
  • Audio effects not working
    Posted by Brandon French on April 22, 2019 at 6:31 pm
    When I go to select audio effects, it allows me to add them, but does not show a pop up menu after that allowing me to change the effect. bypass audio fx is not on. I’ve tried both reinstalling the software and factory resetting it to no results. image to show that i can see my audio effects.
    Brandon French replied 7 years, 5 months ago 3 Members · 6 Replies
  • George Dean
    April 22, 2019 at 9:16 pm
    Hi Brandon,
    When you click ‘OK’ from the Plug-in Chooser (as your screenshot shows), you can not see the Vibrato FX, is that correct?
    It may be hiding behind your Windows Taskbar. Is your taskbar locked onto your Windows screen? If so unlock it and see if enough of the FX shows up to grab and slide it up.
    You could also try a Vegas reset, hold down the ‘Ctrl+Shift’ keys and select ‘Yes’, this will reset all the Vegas settings back to their original installation settings (although it may not restore you FX if the FX is hidden behind the task bar). You should also check the box ‘Delete all cached application data’ before you click on ‘Yes’. That will delete the pesky build up cached application data that sometimes will cause Vegas to do strange things.
    Best Regards……George
  • Danny Hays
    April 22, 2019 at 9:20 pm
    When you add an audio event effect, the effect icon at the bottom right of the wav file should turn green, notifying audio effects added. Is that the case?
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
  • Brandon French
    April 22, 2019 at 9:27 pm
    Hi Danny,
    The effect icon (along with the pan and crop and whatnot icons on the video track) don’t appear to be visible like they used to be. Not sure what’s up with that.
    Brandon French
  • Brandon French
    April 22, 2019 at 9:30 pm
    Hey George,
    At the risk of sounding all rookie-ish, how do you unlock the taskbar? I have tried a Vegas reset but that hasn’t fixed the issue. This response may take some time to show up as I created the account today so I’m still being moderated.
    Brandon French
  • Brandon French
    April 22, 2019 at 9:39 pm
    Deleting all cached application data worked. Thanks so much! (this has been bothering me for months)
  • Brandon French
    April 22, 2019 at 9:48 pm
    Happily, this got sorted. Thanks for your help!
