Activity Forums Adobe Premiere Pro Audio Effects DeNoiser
  • Audio Effects DeNoiser
    Posted by Kevin Gonzales on October 28, 2005 at 3:01 am
    Hi:
    Does anyone know how to use the DeNoiser in the Stereo Audio effects of Premiere Pro 1.5? I have put the effect on my audio track and played with the settings but nothing changes. I’m trying to cut out some background noise. Or, can anyone recomend a good program that is good at taking out background noise?
    Thanks;
    Tim Kurkoski replied 20 years, 10 months ago 3 Members · 2 Replies
  • Johannes Floor
    October 28, 2005 at 8:36 am
    HI: I have experienced the same problem with the deNoiser.
    But if the noise is like low humming or high pitched sounds, u can use the Highpass or Lowpass effects to eliminate unwanted frequencies.
    APP Help: – The Higphass effect removes frequencies below the specified Cutoff frequency and the Lowpass effect eliminates frequencies above the specified Cutoff frequency. –
    U can also use the MultibandCompressor effect to have even more control of each band (Low-, Mid-, High- Frequensies).
    Hope this helps, but I would also like to know how does the DeNoiser work.
  • Tim Kurkoski
    October 28, 2005 at 2:55 pm
    The DeNoiser in Premiere Pro is good for taking out things like 60Hz hum from power lines or flourescent lights, but won’t do you much good for variable noise like wind, crackling, or crowds.
    Audition has an excellent noise reduction filter. Otherwise I’ve heard that the MSU DeNoiser plug-in works well.
