Activity Forums Avid Media Composer Audio editing question
  • Audio editing question
    Posted by David Bispham on October 24, 2005 at 8:25 pm
    In my sequence, which has been edited to my liking, I would like to export the audio to Adobe audition, tweak it a bit and then have AVID use the new(tweaked) audio file, but still maintain the edits. I would like to export, or use a reference file(audio only) of the entire digitized clip and not have to export each individual audio file (where each edit is) and then reimport. Is there an easy way to accomplishe this?
    David
    Kevin Sio replied 20 years, 10 months ago 3 Members · 3 Replies
  • Illya Laney
    October 25, 2005 at 9:17 am
    Can Audition export as OMF? I would suggest doing that, but I’ve never used Audition before. I’m strictly Pro Tools.
  • David Bispham
    October 25, 2005 at 1:03 pm
    Adobe Audition cannot write out an omf.
    But shouldn’t I be able to do my audio tweaks in Audition, save as aif, reimport and then I guess somehow relink the video to the new aif? As long as I don’t cut out or add anything to the wave form the timing should stay the same.
    David
  • Kevin Sio
    October 25, 2005 at 6:25 pm
    David
    I do this all the time with Sound Forge, how ever that’s a 2 track only program and I’m betting that you want to use all the tracks. My suggestion is whip over to the Avid Community Forums http://www.avid.com/exchange/forums/ and try your question there. I am pretty sure that you can find your answer in active exchanges or in the archive.
    they switched to new forums about 2 weeks ago so old info will have to be search for in the old forums, but you should be able to figure that out.
    Kevin
    Kevin Sio
    Videographer/Editor
    Corporate Communications
    National Grid
