Activity › Forums › Creative Community Conversations › Audio editing in FCPX and Premiere Pro
Tony West
September 4, 2017 at 5:25 pm[andy patterson] “He used the ripple edit tool when he should have used the slide tool. “
He used that also. He slid it just like you in the same video you posted. Just before he popped back over to X
[andy patterson] “Who cares?”
I do.
Let me ask you this, when you cut in X are you in the select tool more often or in the position tool more often?
I bet you’re in the select tool more often, and you know what that means? : )
Robin S. kurz
September 4, 2017 at 9:12 pm[Tony West] “… and you know what that means?”
That’s an entirely rhetorical question, right? Cuz I’d say that clearly answers itself. ????
Andy Patterson
September 9, 2017 at 7:59 pm[Brian Seegmiller] ”
You only showed editing audio, NOT VIDEO!!! Let me repeat that, NOT VIDEO!!! Jesús Pérez-Miranda showed how moving video around does not mess with the tracks. You showed nothing of the sort. Let’s see you move Video Clips around and not mess with audio.”I only showed how Premiere Pro can edit audio easier than Jesus did in his demonstration because I did not want the video to be that long. Having said that editing the audio faster should have been enough for you to admit that Premiere Pro can edit audio as good if not better than FCPX and that Jesus’s demo had some serious flaws. I have a new video up showing that I can move audio and video clips much easier than Jesus using Premiere Pro. I am not saying it is easier than using FCPX nor did I ever. I think you have to admit I did edit much more efficiently than Jesus considering he never completed either task using Premiere Pro and let the viewers think it was impossible to do the edit in Premiere Pro. I was able to complete both tasks very easy. How can you explain that Brian? Is Premiere Pro an inept editing system or can you admit Jesus’s demo had a lot of user errors?
Brian Seegmiller
September 10, 2017 at 9:51 pmAndy, In on sentence you said, “I have a new video up showing that I can move audio and video clips much easier than Jesus using Premiere Pro” and then the next you say, “I am not saying it is easier than using FCPX nor did I ever”
